| Hi matt,
 > This of course will only work if I can save the camera position in the 3d view so its the
 > same for every model?export session - is this currently possible?
 If you save to a 3DM file, the 3d view is stored in the 3DM file and will get restored to the same position and direction when you reload the file.  You would need to be careful though  not to rotate the view to some different angle and then resave it again. You might want to write down the current view angles so you would be able to restore them in that case, you can get and set the angles for the current view direction under Options > View > 3D View angles.
 re: scale - I'll see about doing better control of the scale.
