Additional Commands: Merge
6195.2 In reply to 6195.1
This will works only if
"The edges must be tangent where they touch each other in order to be merged together into a single edge".
If you move the curve C2 from B to the curve C1 on A, you can "merge" the 2 curves! ;)
Edit : in fact that is false because these curves are not part of volume or surface, so the merge function will not work!
Use Join and rebuild !
EDITED: 26 Sep 2013 by PILOU
