edit an extruded part, .dxf file, dimensioning
6173.4 In reply to 6173.3
No problem Marv!
It's probably possible to get CorelCAD DXF import working ok too, it's probably a matter of telling it which unit system the DXF file is set in, some programs don't know how to find the unit setting in the DXF file since it's kind of an obscure thing.
Also make sure when you do the DXF export out from MoI have your unit system in MoI set to what you need, don't leave it as "no unit system" since several other programs don't support that concept of a non-specified generic unit and may instead decide to use some other default like millimeters.
