How to put lines exactly onto a surface?
6171.18 In reply to 6171.17
Hi Ditto,
> Can I temporarily change program options during runtime?
> By 'temporarily' I mean, options are changed, but not saved.
One thing you can do though if you want to be able to easily revert back to some saved group of settings is to make a backup copy of your moi.ini file, then when you exit MoI copy the backup copy of it over onto the main moi.ini file again. That will then restore all settings.
You can find out where your moi.ini file is located by going to Options > General and push the "Edit .ini file" button, the dialog that pops up will tell you where the file is located.
