saving join & loft
6154.3 In reply to 6154.1
Hi Marv, yeah like Brian writes above please post your 3DM model file instead of only a screenshot, that helps a lot when taking a look at what's going on in your particular case. Maybe there is some problem with those particular curves.
One thing to note is that there is a final stage in the Loft command where you can adjust options, you need to push the "Done" button (or right click in a viewport which is a shortcut for "Done") to completely finish the Loft command before you go to do a save. If you try to save while you still have not completely finished the Loft command, it will cancel the Loft command. Is that possibly what you have run into? If that's not it, please post the model file.
