Hi Max, you can set this up in your current version if you want.
If you want something that works like videogame movement, go to Options > View > Rotate/Pan/Zoom options, and at the top set Rotation style = "First person". With that set, now mouse movements will look left/right/up/down in video game like fashion rotating around the camera point instead of pivoting around a point of interest as they normally do.
Then to make the arrow keys work go to Options > Shortcut keys and set these keyboard shortcuts up:
| Key | Command |
| LeftArrow | script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'right', 3.0 ); |
| RightArrow | script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'left', 3.0 ); |
| UpArrow | script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'down', 3.0 ); |
| DownArrow | script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'up', 3.0 ); |
