Hi Ditto
You could use the directional array to create copies of evenly spaced objects between two points. Just use the "Extend, Count" option in the commands dialog...
quote: With "Mode: Extent, Count", you also give an item count and 2 points, but the distance between the points is taken as the full extent, with the offset distance between copies being calculated as a distribution to fit inside of that.
