CAIC WZ-10
6080.10 In reply to 6080.9
kevjon,
>The front and rear of the winglet has lost its airfoil shape when lofted with the fuselage which makes it look quite blocky.
Yep, I'll try to fix it. I tried to make it with loft and blend but do not like result, if you will watch video you will see it. Looks like I just have to tune a bit profiles of loft to make wings more round.
>Thanks for the response regarding number of points. I assume you just use the add point command or select a point and hit the delete key till they are all equal.
Yes I just add/delete points.
Portfolio: www.samardac.tumblr.com
