Hi Burr,
> the translation of MoI's surfaces to other apps, will result in "Shrinking the trimmed surfaces"
That only happens with SAT format export, as a side effect from splitting closed surfaces. It's something that you can turn off, if you go in moi.ini and set:
[SAT]
ExportSplitClosedSurfaces=n
It defaults to splitting turned on because I originally added SAT format for transfer into Revit and it did not like to handle closed surfaces in there.
