Michael is it any way to make some upgrade.
For example if we build object from joined curves this object will always have seams where those curves was joined.
So I need every time run rebuild command on curves or manually delet corner points to make one curve.
To get perfect object only with one seam. Latter those seams can be reason of different problems. I always try to keep only one seam when create object.
My suggestion is: Is it possible when you join curves to make one curve not 2 joined? Some script would be good.
Uploaded with ImageShack.us
