Fixing Blend problem
6063.6 In reply to 6063.5
Hi Andrei, thanks for posting the files for me to test with, it helped me to track down a bug in the new Blend stuff that I'm working on.
The update to Blend looks like it should help with this situation - basically instead of only being able to select a single edge on either side of the blend you'll now be able to select a sequence of edges on either side and as long as the edges and surfaces under them are tangent to one another you'll be able to get one single blend surface result like the attached version.
I think it should help for situations where you would previously have to build a bunch of separate blend pieces.
