need help starting 2.5d
606.17 In reply to 606.16
Hi Graham, it's not clear to me which parts you're trying to boolean together.
Are you trying to cut the upright wavy "Q" walls with a curve?
If you're trying to divide it in half by a line, you may need to move the line up in Z away from the middle of the shape. That's because a straight line right in the middle of the shape kind of has 2 directions that it can possibly cut the shape in. If you move it a little distance away from the shape, it will clear up which direction the cut should go.
But I'm not sure if that is what you are trying to do there.
