OSTexo
>I would not use loft for some operations for the simple reason that using loft makes a mess of the control points and desired modification becomes very difficult if not impossible.
It's because you use Loft style - Normal and Profiles - Auto. With - Loose, Exact you will have the same amount of points as extrude have, and a lot less then sweep or network. And any modification is very simple.
