particular points
I have a file where I've crearted points with construct-curve-isect and the resulting points are overly heavy and cant be deleted without a crash (well, I didnt wait excessively long to see if it completed)
The saved file also becomes over 500 MB (which is inconsistent with a normal 3000 point file)
I just thought you may look at it. I dont need anything fixed or worked on with it.
Just run the file and run the isect command on the surface with the lines to generate the points. Saving is sluggish and deleting the points seems like a lock..
