loft (loose, exact)
6016.2 In reply to 6016.1
Hi Andrei,
> Michael why I can not get the same amount of points on surface
> as I have on curves? by doing loft (loose, exact)
It's because your curves are closed and do not all have a uniform start/end point to them. Inside of Loft in order to connect closed curves up without a twisting action happening to them, it has to basically cut the curve into pieces and rejoin those pieces so that the curves can connect together without any twisting happening between them.
So after the curve seams are aligned each of the curves ends up with a slightly different structure in them, and in order to do a loft the structure of all the curves get combined together into the generated surface.
Normally you should not really worry so much about how many control points is in the generated surface, look at Loft as more about generating a piece of material from the curves that follows their shapes. If you need to edit the loft it's better to edit your original curves rather than trying to do control point editing of the generated surface itself.
