Copy enhancements
5976.1
Hi, I just saw a feature from sketch up that will be a great addition to MoI and an easy to implement I hope. When you copy an object you can make a linear array just by typing "*9" for example and then it will repeat the distance and angle of the first copied object to have a total of 9 copies all that inside the copy command. Also you can type "/9" and then there will be a total of 9 copies between the original object and the first copy. It may work this way (so obvious): while being inside the copy command, you make one copy and then you type *x or /x and it will make the array and then you can re type the number or finish the command. It will be a very welcome addition.
