circular and const dist fillet
5942.10 In reply to 5942.1
With "Circular" the fillet cross-sectional shape is always an arc of the specified radius, and in areas where the surfaces being filleted change angle to one another it will make either longer or shorter length arcs of one certain radius, like this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2457.2
With the "Constant distance" type fillet, the fillet rails (the edges on either side of fillet surface) are generated to be a fixed distance value apart from one another, and then an arc is filled in between the surfaces and the radius of that arc will adapt to whatever radius is needed to fill it in, so the arcs that are generated with this method do not all have the same radius but instead have the same chord length between their endpoints. The arc's radius will be larger or smaller depending on the angles between the surfaces at that particular point along the fillet.
