holes and booleans
5934.2 In reply to 5934.1
Select the surface, then select the edge of the hole and hit delete.
For the holes on the side area, that are "open", you will need to untrim the entire surface (Select one of the edges and hot ctrl+a and then delete) Before you do that, you may want to grab your boundry edges to use to retrim the larger untrimmed surface afterwards.
