History and array
5930.2 In reply to 5930.1
Hi shayne, unfortunately I found at one point that the method MoI uses for storing history with storing it on the result objects was ending up making a large file size when there was a large array of curves for example, with each generated curve having the history data saved with it.
So because of that file size bloat from large arrays, none of the array tools have history enabled for them and there is not any way to adjust that currently, sorry.
In the future I want to significantly rework how history is stored and save it in a centralized list that is a sequence of actions rather than it getting saved as additional data only on result objects, when that work happens it should then be possible to remove this limitation and have history and array working in combination with one another.
