Render to Clipboard (Linework)
5927.1
Hello,
When producing assembly guides we use the (Shift+V) command to enable the outline mode and screen grab the elements we need.
However we can't use the built in (copy to clipboard 'V') feature along side this as this disables the outline mode and reverts back to shaded.
This means we have to use the windows screen grab tool which often produces low res images.
It would be useful if we could use the copy to clipboard screen shot to capture outline mode.
Many thanks,
David
EDIT: To add to this, is there a way to prevent linework from showing through thin surfaces. See the attached file. The circular disc in the center should be clean white without underlying artwork.
EDITED: 29 May 2013 by DAITKEN
Size: 32.3 KB, Downloaded: 82 times, Dimensions: 531x904px
