Problems with exports to AI and DXF
5914.2 In reply to 5914.1
Hi Paul, can you also attach the DXF file that has pieces moved around so I can take a look at the DXF too?
What program are you reading the DXF file into? Certain programs are not able to read some kinds of data from DXF files.
Since you already have your curves all arranged in a plane already, when you export you probably want to set "Export type = 3D curves" which means it will write the curves just as they are rather than doing any kind of planar projection on them.
But anyway if you also attach the DXF file that has stuff moved around in it, that would sort of help to see what problem you're running into since it's hard for me to understand what you're describing just by "moved around in a weird way"...
