Does the AI (Illustrator) format not support layers or styles
5911.5 In reply to 5911.3
Hi DesuDeus,
> My question is, will it export planar surfaces (in 2d planes) as
> color filled shapes in illustrator ?
No, it won't do this currently.
> Also, would it be possible to copy-paste curves from MoI 3D to Illustrator ?
> That would be overkill for designing icons and stuff :D
I've been looking into that a bit, but one complication is that there are some parameters you can set when you generate the AI file and so it would be weird to pop up the AI options dialog every time you did a regular copy, because I can't tell at that time whether you're intending to paste 3D geometry back into MoI or whether you're actually going to be copying over to Illustrator.
So I've thought maybe about making a separate command for copying illustrator data to the clipboard, would that work?
