Clothoid 2 point curve script
5878.4 In reply to 5878.3
Thank you very much Michael.
Your code seems to be just what is needed.
I'll try it out after work.
The two selection points need to be on a 2d plane.
The plane needs to be addressable in x and y coordinates, in order to plot the curve created with points
derived by mathematics with x and y values, which I guess is what the var cplane = pointpicker.ptframe; does.
I do not know why it did not work with the Right view.
Or maybe I can set a frame on the 2d plane?
I think that the catenary curve could also be done this way...
