Need some advice on bad geometry from NX Unigraphics
5870.19 In reply to 5870.18
Hi sneather,
> I assume that it won't affect my reliable v2.52, right?
Yeah it should not have any effect on v2.52 .
> With ViaCAD, I did enable the STEP import option to "Stitch Surfaces Into Solid".
> Perhaps that helped with the dodgy geometry?
Hmmm, probably that particular setting doesn't control that. Some other programs based on the same library that ViaCAD uses have options for turning on or off "healing" of the imported geometry. I thought ViaCAD might too but I see it doesn't. Maybe ViaCAD just has that permanently turned on.
> But with the NX STEP file, I had to back WAY off to .001 to approximate
> the same edge profile.
> So, I don't know what to do to figure this out.
I guess I'd need to know more about which specific edge you're trying to bevel in each case to be able to give you more information about this one... Are you sure you're not trying to bevel an edge that is just longer and on the outside of the object in one case but then doing one that is much smaller on some little portion of one of the inside details in the second case?
