Need some advice on bad geometry from NX Unigraphics
5870.16 In reply to 5870.14
Hi sneather,
> I installed a trial version of ViaCAD Pro Mac, and the original STEP file imports with no obvious
> geometry defects. So, it does seem to appear that MOI might be having a little harder time
> with certain STEP files.
Also I think in ViaCAD there are some options for "healing" the file which tries to automatically modify problematic geometry, it could be possible that is actually repairing the problem. That's probably also why it's taking a while for it to process it. It's pretty hard to know for sure without more detailed examination of the STEP file.
ViaCAD also comes in a less expensive version that's just $99: http://www.punchcad.com/p-9-viacad-2d3d-v8.aspx which I'm pretty sure also includes STEP import - it can be a pretty useful tool to add into the mix.
> I need to check on the option to send you the original STEP file. Unfortunately, I have certain
> agreements with the clients, so it may not be possible. I hope you understand.
Certainly, I understand, and please don't do anything to jeopardize the relationship with your clients. Sometimes it can be hard for me to give very much specific additional feedback about file translation issues when the actual files involved can't be shared though.
Also if you need to keep something private you can send it to me through e-mail at moi@moi3d.com instead of posting it here on the forum.
EDITED: 1 May 2013 by MICHAEL GIBSON
