Need help !
5795.7
If you want to build the terrain inside of moi I would use the DXF file as a reference point (freeze it) and snap new curve lines to it in a square (or rectangular) grid and the create a network on that. It's a little arduous but works well and if you keep the curve lines you can modify the surface as you go.
http://www.suburbanartworks.com/
