| Magnificent amount of work Michael!
 > Implement view spinning - Add a script method for view spinning that can be set on a keyboard shortcut:
 This is awesome!!!
 It really works great as a companion to "Free Rotation" view manipulation mode!
 After 'spinning', the only way I've found to reset the view back to the original horizontal-0 if this was implemented in "Rotate Around World Axis Z" mode is to switch to "Free Rotation" mode then back to World Axiz Z, where the view port will reset.
 But yes! You can now rotate the 'ortho' viewports which helps you to get a better look at your work.
 Reset the spin angle in ortho views by clicking on its your current view's activation button twice...  (right>left>right)  Cool!
 Also, would it be someday feasible to implement 'Spin' with other viewport manipulation methods, such as with a View Control button for fine-tuning, or maybe a way to do it on the fly with mouse manipulation?
 Thanks!
