union failing
5769.12 In reply to 5769.11
Hi Ari - you shouldn't have to create a commands folder, there should already be one there with all the regular commands (like Line, Extrude, Sweep, etc...) all in there already, you need to put those ScaleArray files into the same spot as all the regular commands.
So I think you probably don't have it in the right folder - when MoI tries to execute a command and it doesn't find any files of that name in the commands folder, it tries to execute the text as inline script code, that's what generates that particular error message that you're getting.
To get to the right commands folder on the Mac you need to right-click on the app and pick "Show package contents", then inside there go to /drive_c/moi/commands - that's where you'll need to copy the files into. Once you do that then you should be going ok.
