Tangent to curves
5758.2 In reply to 5758.1
Hi Brian, probably the easiest way is to use the BoundingBox command to generate a tight fit frame around the curves, it will then intersect the curves at the points you want I think.
You can also draw in a line or a construction line using Perp/Perp snap to get things like that too, see here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3042.14
http://moi3d.com/forum/index.php?webtag=MOI&msg=3042.13
