image import pdf
5734.7 In reply to 5734.6
The easiest thing for a bitmap in a pdf is if you just left clcik it it will "highlight" and then you know it's a bitmap, then you can just right clcik it and "copy image" to paste to whatever. The pdf printers will be manipulating bitmaps too though, during print. Like setting dpi's and resizing and stretching for the output type, so you may not be getting original qualities. It's not the best way to pass around images.
