image import pdf
5734.4 In reply to 5734.1
Hi eric, yes like Marco writes above using File > Open or File > Import MoI will only look for vector path information in PDF files.
Probably your PDF only contains a bitmap image in it (is it maybe a scan or something like that?) and doesn't have any curve data in it. If that's the case then MoI's Open command will not find anything to use in it.
If you wanted to bring it in as a background image and not as curve geometry, you need to use the View > Image command for that but you will need to convert the PDF into a regular bitmap file like JPEG or PNG for that, the background image command only uses simple bitmap files like PNG, JPEG, etc... Someday I would like to make the background image command work directly with PDFs as well, but they are quite complex to fully display.
