Any Sneak peek of the next beta ?
5721.28 In reply to 5721.26
Hi Martin,
> I've lifted this from the Deform Face tool Help facility (Pressure, Point and Curve Deform) in ViaCAD
> Pro v8 and made it into a very short video which can be paused if needed.
Those are interesting but also a bit weird too - if you wanted a bulging surface in that area why would you start out with a totally flat plane instead of actually constructing a curved surface by sweeps or some other construction technique?
Have you yourself ever had occasion to use those tools in ViaCAD pro for a particular project?
At any rate, the current hole filling mechanism that I'm using is a pretty separate thing from that.
