Any Sneak peek of the next beta ?
5721.19 In reply to 5721.15
Hi Steve, one thing that I've experimented a little bit for the sharply meeting surfaces case is to put in little corner blends like this with poles at the corner spots:
Then that leaves the rest of the area with only G1 meeting surfaces to be patched:
If you want a smooth blend surface fitting into a sharp corner, probably it's going to need that kind of surface with a pole in it (like the tip of a cone) to get that.
But this has some problems - in general the more little surfaces that are used will tend to leave evidence of their construction in the final shape.
There may be some possibilities with an automated blend using that method though, but I'm not sure if I will be getting to that level yet with this current pass.
