Solid Modelling and Offset shell
5670.1
Been playing with some solid modelling again, well rather making surfaces and then joining them up and the shelling the shapes. Is there a way Michael of making the Offset/Shell command stay planar ?
I can work around the problem but it would be nice to not have to.
Example of what i mean is attached below... If you do an Offset with the BodyBulge file .. The offset is 0.25
As you can see I have been working on some snap fit valves for tubeless tyres and Having to pull these pieces apart to fix the problem is a little tedious
Martin Spencer-Ford
EDITED: 26 Jun 2015 by TPWUK
Size: 291.8 KB, Downloaded: 141 times, Dimensions: 1920x890px
