How would you model this? Organic shapes...
5668.12 In reply to 5668.8
> Hmm, I'm not having any luck with joining the surface model to the solid base, and I didn't
> find anything regarding this specific in previous posts. Are there any tips for doing this?
You'll probably need to reverse the process a little bit - build the bubbly surface piece first, then trim that how you want it and use the resulting edge around the outside of the bubbly surface to construct a base piece.
It's unlikely that ZSurf is going to generate something that matches a predefined fixed base within enough tolerance to join it.
