> yes but when original OBJ object has not double edges you can"t make in Moi in one
> pass all planar faces of the imported model
> You have each line yes, but not all faces as separated faces so planar
> don't work in one pass
That's not true anymore, there is now a second mode for the OBJ converter that will make one closed polyline for every face, instead of one line for every shared edge. It puts up a dialog that gives you the option between those 2 modes.
I think you're remembering only the original mode that it had and not the new one.
See previous post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5135.5
