Hi DesuDeus, yeah the way it works is each window represents a separate "instance" of MoI and each one writes out its current settings to moi.ini when it closes. If you have more than one window open make sure to close the other ones before you edit the .ini file.
I'd like to change how this works in the future so that an instance will only write out a particular setting if it had actually changed rather than just always writing out all current settings.
