Max number of objects
5641.3 In reply to 5641.1
Hi Moritz,
> what is the maximum number of objects in one scene?
There is no specific maximum.
> When I try to select all of the objects in this scene, I get a count of 134
> objects and they are NOT all selected!
Those particular names that do not show as selected are ones where the name is assigned to sub-objects (edges or faces) instead of the top level object.
You can get that either by assigning a name to a sub-object selection.
Like for example the one that you have circled there named "hallenboden" is the inside floor face of the larger parent object which is itself named "haus". The face will only show as selected when it is specifically selected by sub-object selection and not when its parent object is the one that is selected. But maybe I should change that, what do you think?
