Advantages of v3 for "meshing users"?
5637.5 In reply to 5637.4
I export some mesh objects from Rhino as FBX and reimport it. The objects are on the original layers. Also last I got a FBX model from a client, there was a layer structure implement - very useful.
Layer are quite important for rendering - my clients are using it for sorting materials but also for easy allow to switch between design versions, for example an airplane seat with table in and out.
Attached a FBX in ASCII format there you can see the used layer properties. Only the layer colors are not set yet.
I hope it can be implement. Funny, this way was open since years, but I ask you for OBJ/3dm and layer only always. I didn't know that FBX is so powerful. It seems to be that it can save NURBS too, Rhino ask for it during export.
Visualisation for Designer and Architects | http://www.simulacrum.de
Size: 34.4 KB, Downloaded: 57 times, Dimensions: 344x299px
