New to MOI - should I start with V2 or the V3 beta?
5634.5 In reply to 5634.1
Hi Paul, it's a big goal for the betas to keep them stable and so I'd recommend using v3 - it's just got the all the latest stuff in it. V2 is starting to get somewhat old at this point.
> Also - is there a recommended learning path for this? I see that the only personally
> available learning items seems to be user and developer-created tutorials, is this correct?
Yup, that's correct. Probably the easiest starting path is to watch the video tutorials here:
http://moi3d.com/2.0/docs/tutorials.htm
Those go through creating a few simple objects step by step discussing details along the way, they are good introduction to the general modeling method and workflow.
Then there are a bunch of other ones collected here:
http://moi3d.com/resources#Tutorials
And then the forum here is a big learning resource as well - if you run into things that are confusing, hop on here and post a question about it - it helps to include your model file along with your question.
