Hi Petr, thanks for posting the example!
It appears to be a problem with curves made up of 2 segments, things are getting confused and it is trying to use the same fillet solution twice. It works when doing it on separate segments because that uses the spot that you click on as a guide for which fillet solution to take.
I should be able to fix this up tomorrow for the next beta.
