Imported object orientation and imported object scale for ai-file
5625.3 In reply to 5625.1
Also another option for orienting the AI file is to use the "ImportPart" command, that's available by right-click on the Import button. It will then use the orientation picker to let you position the just imported objects.
But the orientation picker mechanism is more set up to orient things onto objects, like if you wanted to stick the imported file onto the side of a box it would work easily for that, but for doing things between views doing a regular import followed by orient view to view as shown above is easier.
