New Sep-4-2006 beta available now.
56.3 In reply to 56.1
History Edit Curves works fine!
(You Must enable "Show points" for modify the "Historic" curve, ist that normal? )
History Edit curve don't work for a curve of an object trimmed or a "draw solid"? ist that normal?
For Copy Multiple ? (Button "Make Copy" is maybe not a Copy Multiple or an array Copy of object?
Check boxes Yes for the copy but what about the number of copy?
The Ctrl during a Move works fine:)
Untrim (delete) works fine ;)
I had seen that Space Barre Selection is added for Select/ Deselect :)
Maybe "I" as Inverse Selection will be fine ?
(or better include as third choice in the Space Barre selection? Is that possible? it will be tricky and very useful)
A function "Hide Inverse Selected" will be also a task :)
EDITED: 4 Sep 2006 by PILOU
