Hi Martin,
> Basically, is there a way to prevent the main headings moving from their shrunken location
> so I can go straight to them without hunting?
I guess I'm also not exactly sure what kind of "hunting" you're asking about - are you having difficulty just locating the tabs at the top of each section?
Those usually don't need a lot of effort to be located, they're always at the top of each palette section... and the active one has a blue color that nothing else in the side pane has, so those tabs normally jump out fairly easily at a glance.
I probably don't quite understand exactly what problem you're running into though.
Is it possible that the UI is slightly too small for you to see things easily on your current screen? If so you can adjust it to be slightly larger to increase the ease of just seeing it in general, go to Options > General and move the "UI size" slider over a bit to increase the size of all the buttons and everything in the side pane.
