Hi there,
I was wondering if it's possible to do something like the Push Pull in sketchup.
You pick a closed curve (or a surface) on a solid
or
You pick a closed curve (or a surface) then select a solid
Then
Extrude in one direction = regular extrude
Extrude in the direction of the solid, once you intersect with it = extrude then boolean
Instead of calculating the boolean in real time it would just display the hidden line (kinda when you use the move command)
Sound possible ?
