V3 beta Nov-6-2012 (Win/Mac) available now
5524.51 In reply to 5524.50
Hi Martin, so there is actually a way for you to whiz through the fonts currently - to do it click on the font dropdown once which will open up the dropdown, and then click on it a second time which will close the dropdown but maintain keyboard focus on the control itself.
Then at that point you can push the up or down arrow keys on your keyboard to rapidly whiz through different fonts and see it update continuously.
Also another method you can use without any clicking is that after you launch the Text command push the Tab key twice which will put keyboard focus on the font dropdown also and then you can use up/down arrows after that.
I did a quick experiment with trying to get the scroll wheel to work, but that particular behavior with the scroll wheel on those kinds of controls does not seem to be enabled in the WebKit infrastructure that MoI uses for all that UI, so it would likely be a fairly involved matter to enable it.
I hope though that the up/down arrow key action that works currently might be a good substitute since it's quite similar.
