V3 beta Nov-6-2012 (Win/Mac) available now
5524.111 In reply to 5524.110
Hi Martin,
> Using the Shell tool to thicken it up a bit, gives a rough result and
> I wonder if this can be tweaked.
> The other cone was made from a revolved line and the surface thickened in the
> same way as before, but this time, has turned out as expected.
I've got this updated for the next v3 beta - in the next beta when using Extrude to point where the base curve is a circle or arc shape, it will make an analytic cone surface out of the result and that will help this case to offset properly.
Thanks for reporting the problem,
