Hi Martin,
> Is there any reason that a zero value entered into the 'Thickness' property couldn't be made to work
> - I'm thinking that it might be a way of offsetting an entire surface by the amount entered into
> the 'Use separate height' property?
"If I understand you properly, you can instead use the Construct > Offset command to generate that kind of full surface offset."
Hi Michael.
What I had in mind was that it could be used to alter the thickness or width etc of the part and keep it as a solid, rather than offset a separate surface from that solid - I suppose it would be the equivalent of an 'offset face' operation in other software.
Martin.
