New Apr-18-2007 beta now available
550.33 In reply to 550.26
>>It should generally handle non-intersecting curves already...
Yes, it handles... but it's a funny story. When I sketched my firts set of curves for "networking" I couldn't manage to get anything. I looked into that and found out the curves didn't intersect so I supposed the command worked only with intersecting curves. I'm not able to repeat this situation, although I have been trying it :). If I encounter failure of network command I'll tell you about it.
>>Do you have an example of the type of thing you would use the tolerance for?
I'm used to driving a surface's complexity by changing a tolerance in Rhino when using "unsightly" curves as an input to create a surface from a network of curves. It seems to be quite useful feature.
>>I guess there could be another button that said something like "delete projections"
There is an issue of multiple projection I didn't notice previously. So I guess no changes in the current projection tool are the best.
Petr
