Center model on world axis zero coordinates?
5427.11 In reply to 5427.10
Hi Martin,
> Michael, may I suggest "Pick center of bounding box" or "Pick bounding box center".
The tricky part about button text (text going inside an actual push button) is that when it's pretty long it can easily wrap to multiple lines in that narrow side pane area...
I don't worry about that so much with prompt text (the description at the top of the command area that tells you what MoI is expecting for you to enter next), but for push button text it's kind of good to try and make it shorter.
